Yes I am lolYou are Tune for sure to get 14.04
You ran a 15.8 and had better times than Gens? O_O Yowzers. You'll get better, don't worry. Practice makes perfect.Was my first time ever at a dragstrip. Best run out of 3 was 15.8 and I'm fully stock, even the crappy tires. Not sure if this time is any good but I had tons of fun and had better time than 2 Gens that I came together with.
What is the best way to take off in VT? First run (ever) I held it at around 4.5K and then WOT and dropped the clutch.. Resulted in spinning tires in one place until I hit 3rd, then I started moving...
Second run I held rpms at around 2.5K and then WOT, did much better, but still it was only 15.8...
Wonder if I should not try to gun it right off the bat but apply gas gradually?
Any suggestions? (Other than more practice)
will check the slip and add it hereWhat was your 60 foot time?
the slip would tell you where you should practice, usually launch, i was still on stocks.. waiting for it to get cooler and maybe by then i need new tires and will go againt to see if i can hit thirteenswill check the slip and add it here
good to see your trap speed is getting thereDon't think I ever posted my last slip here View attachment 36110 I'm the one on left from a bit ago
Hopefully better when it's colder out!good to see your trap speed is getting there
I had Traction Control off the whole time but am wondering if leaving it on might have helped with the wheel spin (yes, wheel spin was mostly my mistake)?On stock tires, drive around the water box and don't launch as hard, just feather the clutch till you get traction then let it rip
traction control could possibly help on the launch if your new to launching fwd cars, But the down side is could activate on some harder shifts and kill your time there.I had Traction Control off the whole time but am wondering if leaving it on might have helped with the wheel spin (yes, wheel spin was mostly my mistake)?
Has anyone compared the runs with and without TC on?
Boost is different during WOT with ECO mode on. There are different calculations made with ECO mode on vs off when identifying the primary commanded torque table inside the ECU. I want to say there is a time window as well (I think its 5000ms) that disables ECO mode when you go WOT.Eco mode is disabled on WOT, no worries there.
Not bad times, considering the mods you have... it looks like they added to the advertised 1/4 mile times!Made 3 passes at the local strip today.
Auto trans
cone filter only
axle back removed in favor or straight pipe
tork pipe
15.6 @ 89 .8 rt
15.5 @ 92 .7 rt
15.4 @ 92 .5 rt
Left the eco mode on for all of them like an idiot...
I hope to see you back on the track soon!Hopefully better when it's colder out!
