Hello,
(PROBLEMS LISTED AT BOTTOM). I just finished building my 13 VT. This is my Daily and my goal was to build something that was efficient on gas but I could also have some fun when needed. It has less than 500 miles on the engine. I am having two issues. A little background about this build. This is my 4th engine build and I have 10+ years of mechanic experience. This has me stumped. Any help or advice is much appreciated. I have no Cel.
The build (13 Stock Tune):
- Bored block to 77.5 MM and decked at Shacklet automotive in Nashville
- Head built by Shacklet automotive in Nashville
- 77.5MM Traum Pistons
- Molnar rods
- King Main bearings
- Hyundai rod bearings
- New OEM Coil packs
- HSK Spark Plugs
- Injen CAI
- Tork Pipe
- Tork Motorsport Downpipe
- All OEM seals
- New timing chain components (reused cam phasers)
- Fuel injectors cleaned and tested at Injector RX
- New OEM Borg warner turbo
- Oil Catch can
- Braided Fuel Line
- New OEM HP Fuel Pump
- Upgraded Mac solenoids
- Assco Flywheel
- OEM Clutch
- Braided clutch line
- All new front and reart end suspension
- Problem 1- A rachet sound that I can only hear in the cabin. I have stethoscoped the engine from top to bottom and cannot pick up the sound in the engine bay only in the cabin. The High-pressure pump is the only thing that has a sound that is remotely the same. I replaced the fuel pump lifter and pump and am still getting the same sound. The only time it stops is when I left off the throttle with the car still in any gear and the sound stops. As soon as I touch the throttle it comes back.
- New HP Pump
- New Braided fuel line
- New HP pump lifter
- The tank pump is on order
- Problem 2- Power loss at 4500 rpm in any gear. I think the wastegate is opening at 4500 RMP causing a complete loss of power. This happens with light or heavy throttle.
- I have changed both solenoids with mac vales
- Cleaned the IC during the build. No leaks.
- Turbo smart dual-port BOV.
