1 - 12 of 12 Posts
So this weekend I determined myself to plasti dip my wheels and paint the calipers since the wheels I wanted were backordered and who knows when I will be able to get them. I have never done plastidip but for a first timer I think it was not too bad. The only problem is that after it dried up it started getting patches where it looked to be melting. I did this outside and it was pretty much boiling...could that have been it or maybe my technique wasn't the best? I tried to do thin coats but the eventual over-spray did happen. Anyways I am leaving them on for a while cause I think it looks good overall but if the patches start to annoy me I'll just take it off. Tell me what you guys think.
20130630_140117.jpg 20130630_140117.jpg 20130629_174950.jpg 20130629_175645.jpg 20130629_172733.jpg 20130629_175703.jpg 20130629_170914.jpg 20130629_141051.jpg
i like the look of the wheels and the calipers. i have not seen the problem you had with the wheels but my first guess would be how did you clean them before spraying the PD?
Warm water and a cloth...nothing crazy...should I have used a special cleaner?
They recommend some pretty heavy duty cleaning before dipping wheels on the dipyourcar forums
Reactions: phrozenghost
Did you plastidip (spray) the capillars? They look good
Peel it off and then clean it with denatured alchahol after a mild soap/water combo. This should ensure a good bond between the rim and the PD. Or you can always just get the pre-dip from Dipyourcar.com
1 - 12 of 12 Posts
