This is not on stock suspension correct? What exactly is your suspension setup?ie: springs, coils, drop front and rear?Okay, so last night after realizing that all was great until you pack 85lbs worth of kids and 75lbs of rim/tire and tire in the car that it rubbed.. Rubbed for about an hour so I had to think on my feet quickly..
swapped the wide setup to the front, put the others on the back with the spacers. Still looks quite good and no more rubbing under any circumstance!
wider front tire/wheel makes a bit more sense on FWD anyway. I MIGHT get slightly larger spacers in the back, like custom 12mm somewhat soon.
The car feels better also with the 235's on the front.
The steering response with the Pierce dual bard strut bar + rigid collars + this tire setup is AMAZING!!
Will get a picture up real soon with this new setup
If you ever plan on any weight in the back, I would NOT recommend my initial setup. If you have coils/Konis with the setup I had in the rear set stiff, it might work out OK. If I were to put a 225 on the back it would have worked better but i HATE stretch.
Thanks.
