I am starting this thread and will try and keep up with it.. This will include massive amounts of information for reference purposes, DIY purposes, places to buy aftermarket parts, etc.
I will work on it this afternoon!!! Stay tuned!!
General Vturbo/Hyundai information:
VIN#, Engine#, Transmission# decoder (PDF)
Lift points and Towing Points (PDF)
Stock Specs:
Engine
Detailed Engine specs, tightening torque, etc. (PDF)
This PDF includes everything related to the Mechanical specs of the engine including: compression, stroke, bore diameter, valves, etc. as well as tightening torque related to everything that has to do with the engine from the mounts to the turbo bolts.
Transmission
Insert PDFs here from HMA
Suspension
Fueling
Fuel system and related sensor specs, tightening torque, etc. (PDF)
This PDF contains all the information you could need regarding the fuel system specifications including pressure ranges, related sensors like the MAP, IATS, ATP, BPS, ECTS, TPS and others. Any sensors related to how the car delivers fuel will be included in this PDF.
Lighting
USA:
Headlight (low beam): H11b
Headlight (high beam): H7
Fog Light: H8
Stock Specs:
Engine
Transmission
Suspension
Fueling
Lighting
USA:
Fog Light: H8
