Hello all, new member, first post!
I just bought a used 2013 VT, 88k miles, 6 speed manual, well taken care of, clean car-fax. No known mods other than a K&N air filter element in stock housing with stock air intake. Driving home, car developed misfires, worse under hard acceleration. At steady speeds car ran fine, got 34 mpg on expressway trip home. After reading some posts, I changed the spark plugs due to mileage. It seemed to help at first, but misfires returned. Plugs removed had a bit of brown discoloration, but not burned, wet, caked with deposits or any damage to ground electrodes or porcelain. Gaps only slightly larger (maybe 0.035" max) than those on replacement plugs (0.028"-0.030", carefully checked with feeler guage, as I know from my 33 years in the auto parts business that re-gapping Iridium plugs can cause more problems than a few thou variance will) After reading some posts on here about possible coil pack and low-pressure side fuel supply line issues, I hooked up my scan tool. The only codes I have are for misfires, including all 4 individual cylinders (P0301-P0304) and P0300 random, no P0087 low fuel pressure, yet scan tool indicates only 560-580 psi fuel line pressure at idle, and it stays flat with a only a little variance up and down as rpm is increased to around 3500 in neutral (not gonna free-rev it higher than that). Not having much experience with Hyundai (if you need GM vehicle info, I'm your man,...) I humbly turn to you all for help and advice, so as to not throw away money on things not necessary. I ran my VIN on Hyundai's site, and it does not show any recalls or campaigns relevant to it. Thanks in advance for any and all help.
