So I had a bad head gasket no need to go in to detail. I had a machine shop do a valve job and remachine head. I replaced the head gasket and was worried because there isn’t much literature on the timing. I aligned tdc and set with cam/crank marks lined up. Started up had misfire on cyl 4 and P0017 which is a cam/crank correlation code. I did compression test cylinder 1,2,3 had 90psi, cylinder 4 had 80 psi. This seems low to me. I pulled engine back apart and all timing marks seem to line up. There is no visible damage to valves or cylinders. The machine shop I used to do valve job is very credible and very good at what they do so I don’t think they messed up setting the valves. I have to be missing something or doing something wrong. I figured I would pull it back apart and find the chain was 1 tooth off but nope.
