UPDATE: Went and got a new oil cooler from my Hyundai dealership and replaced the old one. I also put some gasket maker between the metal body of the new oil cooler and the engine where it connects for some extra measure. Worked BEAUTIFULLY. If anyone else happens to have this problem in the future
You'll need: (1) oil cooler, (1) 1 3/16th socket, (1) breaker bar 1/2 Inch Drive, pliers, gasket maker (if you want to be extra like me), New oil, more engine coolant, and I recommend some new adjustable clamps for the coolant hoses (the ones stock on the car make is extremely hard to put back on by yourself).
Steps:
1. Drain all your oil starting with your oil pan, then remove your oil filter and allow the rest of the oil to drain out completely.
2. If you can disconnect the (2) coolant hoses that are attached to the oil cooler (Warning: a lot of coolant will spill out so be prepared with a pan to catch it all).
3. With your breaker bar (1/2 inch drive) and your 1 3/16th's socket loosen the gigantic lug nut that's revealed when you removed the oil filter. (This will take a bit to completely remove, when it's all the way loose it will fall out of the old oil cooler, keep this to the side as you'll be using it to re-attach the new oil cooler).
4. - ONLY IF YOU DIDN'T ALREADY REMOVE THE COOLANT HOSES - If you weren't able to previously detach said hoses now they may be much easier to reach due to being able to manipulate the oil cooler in ways to better reach said hoses. Simply use some pliers to squeeze the clamps off the oil cooler and pull the hoses back.
5. Install new oil cooler in reverse order (I recommend applying some Gasket maker (Permatex Ultra Black Gasket Sealant) to the metal body surrounding the o-ring on the oil cooler and the metal body of the engine where it attaches. You can find the exact stuff I used here:
Permatex Ultra Black Gasket Sealant 3oz
6. DON'T FORGET: Refill your oil and engine coolant completely prior to turning your car back on.
- If you decided not to use the stock metal hose clamps like me be sure to reattach your adjustable clamps to the coolant hoses once you're finished putting on the new oil cooler (get the type that you can wrap around the hose and tighten easily with the knob)
- I also recommend unbolting the plastic shield under the car as this will afford you more room to work with.
