21 - 26 of 26 Posts
Discussion Starter #21
Those plugs do not sound good but hoping for the best. Can you do a compression check across all cylinders?
Yeah I can eventually. Next time our schedules work together is Wednesday. Any idea what the compression should be? Or who cares just check to see if it's the same on all 4 cylinders? Plug 3 to me looked like detonation and plug 4 seemed like bad rings causing excessive blow by.
Just check across all 4 cylinders and report back. Any oil or coolant loss? Keep an eye on those.
Discussion Starter #23
Got the OBD2 LX hooked up, read the P0303, p0304 and p0300 codes, cleared them. Had her drive it. Said the car broke up again at 3,000 rpm. CEL flashed and went off. Read the code again. P0302 and P0300. Which would mean after replacing cylinder 3 coil, cylinder 4 immediately went out after. Last update I switched coil 1 to 3 and cylinder 2 to 4 and now 2 is misfiring.
Going to order 3 new coils.
Thank you for the recommendations. Will keep this updated.
21 - 26 of 26 Posts
