1 - 1 of 1 Posts
Vendor
This extremely durable and high quality bracket is constructed out of billet steel. It installs easily and mounts to the existing shift arm on top of your transmission, reducing your shifter throws by 30%. The increased weight of 500 grams also aids in shifting momentum and positive engagement.
The adapter bracket is designed and manufactured in Boomba's manufacturing facility, right here in the United States and all mounting hardware are included. All adapter plates are zinc plated for durability and excellent appearance. A definite mod for daily drivers as well as autocross and road racing enthusiast!
We HIGHLY recommend purchasing the shifter base bushings and transmission bracket bushings at the same time, this will ensure you only have to disassemble everything once.
Features:
-500 Grams of added weight aids in shifter feel
-Zinc Plated for corrosion resistance
-Easy install
-30% Reduction in throws
Available Directly On our Website
Veloster/Elantra/Forte 6MT Short Shift Transmission Adapter
1 - 1 of 1 Posts
