What's up everyone? I've found the info on this forum quite helpful over the past couple of years so I thought I'd share an upgrade of mine that finally came to fruition. Through a lot of research and bit of trial and error I've found that 2011-2015 i40 aluminum control arms are a direct replacement for gen 1 Velosters. They're also about 2 lbs lighter and gave me 1.3 degrees of camber. You will need an alignment after as the toe was way off and you can use the same poly bushings for our cars. The OE part numbers are 54500-3Z000 for the left and 54501-3Z000 for the right but I chose to get Febi Bilstein arms 173585 & 173586 out of the UK. The job is pretty easy if you have a ball joint separator. Let me know what y'all think.
