1 - 20 of 72 Posts
ok so I sent an email over to mandrel exhaust systems earlier this week about an exhaust for a VT and they responded with
Ironically,
We started a system for the Veloster afew weeks ago.
Its a tubing system only (without muffler/tip). You would need to have it installed with a muffler/tip from a shop... unless you can weld to save afew bucks.
Let me know if your interested in the tubing kit?
then when i asked about why no muff they said
When new model lines (like the Veloster) are released we generally start with Tubing Systems to help gauge interest in the model.
There is a considerable amount of time involved in R&D to make systems... and even more to build "bolt on" systems. If the system sells and there is alot of interest we usually revisit the system within several months to compete the bolt on process. Otherwise, it stops at the Tubing Systems.
The only other way we advance to a bolt on system is if a group buy is setup in advance before we prototype.
Not the best answer, but hopefully this helps.
I'm going to see if maybe they could do an axle back.. Their systems are usually pretty good they use magnaflow resonators/ mufflers (or borla muff)
I figured it wouldn't be a bad thing to bring up to people as their tubing kits run from 120 (aluminized)-200 (stainless) and exhausts usually run under 500 bux fully decked out.
I'm interested also.
I'd be interested in a group buy for the bolt-on :smile:
Let's do this!
Let me get this straight... this will be for the piping cat-back correct?? So I would still need muffler, resonators, and tips?
Discussion Starter · #11 ·
for the piping kit yes.. if we had enough people for a group buy on a bolt up catback they'd do that too and you wouldn't need anything.
You'd really only need a muff, the flanges and thats it (maybe a y pipe to fit into the stock exhaust exits)
If the price is reasonable and it sounds good, I'd be down.
Been thinking about the magnaflow set up seen on the NAV... but I would prefer a set up that's tuned for the VT.
Discussion Starter · #13 ·
the magnaflow thats on the NAV would be too small for the VT anyways.
I mean the "cheap" route is just a resonator delete, and muff swap. since the exhaust is already mandrel bent and 2.4" ID
however you'll be able be able to get the piping for just about that price and make whatever setup you want and not have to hack up your stock setup
Vendor
the OD is actually 2.4" (60.3mm)
I still don't see whats wrong with the 'cheap' route. Its not like anyone is going to keep their stock axle back sitting around (I don't know why they would) There would really be no reason to go back to stock if it wasn't sounding like a helicopter.
Discussion Starter · #15 ·
interesting.. so it's probably close to 2.25 ID.. that is smaller then expected a 2.5" ID could definitely help out a bit then
Vendor
exhaust is typically always measured by the OD, no?
Turbosocks, all you did was a resonator delete correct?? Did you ever post up a sound clip??
I've been wanting to do mine, just haven't decide which route to take. I just want a deeper growl than the stock exhaust. More of a note to it.
Discussion Starter · #19 · (Edited)
ID is what matters but some manufacturers go by OD.
I don't think the pipe is 1/8 inch thick.
60.3 mm is 2.37402" standard piping is just about .05" thick so 2 walls takes it to about 2.27" ;)
he did muff delete not res delete I thought it sounded awesome but he said it was too loud under load.. I think res delete only might be the way to go for a cheap route unless you get a bigger exhaust.. and now that I'm seeing it's closer to 2.25" I'm thinking that a 2.5" would be a good upgrade with full bolt ons you're going to have close to 200 whp and on a TC car you want a much smoother exhaust flow. so the larger exhaust would probably be a better idea.. ESPECIALLY for anyone who plans on getting a tune ( as you'd probably be pushing around 230 whp with bolt ons and tune)
So $195 gets you all the 2.5" stainless piping for a CAT back system to the tips with no resonator or muffler?
1 - 20 of 72 Posts
