1 - 5 of 5 Posts
2020 Veloster Turbo R-Spec
Got a 2020 turbo r spec, that has BSM, but doesn't have the turn signal built into the mirror, any way to wire a Veloster turbo premium or n model mirror with BSM and turn signal indicator built in was thinking of just bringing a while from both turn signals in front and wire to the corresponding signals
· Super Moderator
2014 Veloster Turbo Manual
may be worthwhile to check the pinouts at the doors. in the kick panel is a large plug in panel that controls the door electronics you can access it there. with the door open you will see where it connects on the outside with the weatherproof connector.
so i should just put a pin for the turn signal instead of actually wiring it from front turn signal
· Super Moderator
you may be able to considering it is a standard option on other cars... maybe run a multi with the blinker going and go from there?
theres no wire exposed from the mirror
1 - 5 of 5 Posts
