What width & tire are you currently running?I will punch you in the face next time I see you![]()
+38 PLUS another 8mm?? Do you have a pic of how much they poke out?running stock tires on 18"x7.5" wheels. They are 38mm offset + 8mm spacer so they bump out 19mm (.75") more than stock.
I am pondering my next setup though.
Can't decide if I am going to stay full 18"x7.5" with 225/40 all around or so 18"x8.75" in the rear with some 245s...
I can get the wheels that want in either +20 or +35 .... which offset would be better fit for the VT?It would be a little stretched. 215/40R18 rim width range is 7-8.5 so it'll be .25 more stretched than what it should be.
And hey, get off his back socks! real man stretches there tires lol Plus not all tires protect rims. Just know how to park and drive your car and you shouldn't have to worry about rim protectors
BTW depending on what offset that rim are you looking at, it will poke and with the vt/v you can not camber in the rear so it will look gross.
Anytime I want to see a size tire and a certain size rim I just google image it. There is always someone out there who runs them and post pics and what not
https://encrypted.google.com/search...34,d.aWc&fp=f972948f606f9b4c&biw=1366&bih=663
Are they XXR?I can get the wheels that want in either +20 or +35 ....
That is weird because this guy has 18x8.5 +50 245/40/18 and look how flush his is. I wonder if dropped it this much (not that you would or would want to) if you would tuck or rub.yep, basically running 18x7.5 with 30 offset, no poke, almost flush.. The 225 tires should make it pretty darn flush and fill the wheel wells a tad more!
OH MAN that looks hot. I knew you wanted those after seeing the rim you wanted lol
What's the stock width / offset?
7.5 width and I have heard anything from 49 to 46 for offset.What's the stock width / offset?
