I have a 2013 VT 6 speed manual with about 64000 miles on it. I have had it for a little over a year now and I am the third (maybe fourth) owner.
I didn't realize it when I bought it (first manual, second car) but it has issues shifting, especially at high rpm. This might be a long post, but I am trying to provide as much info as possible.
I finally brought it to a shop, they said it needs a new tranny. $2500 dollars. I took it to another shop and they said same thing but dude was kinda shady. I had a fairly trustworthy independent mechanic that told me a while back he thought it was most likely the clutch, but said to wait until it really went out. Anyways, the first place I recently brought it to changed the fluid twice and it didn't really help at all. The old fluid was fairly dark and had tiny, fine, glittery metal particles in it, I had changed it once myself within the last year.
So, I am not convinced its the tranny, but I simply don't know. Here's why I am not convinced.
Before I just got the fluid changed, it seemed to only be really bad from first to second, to third, sometimes to fourth. Again, mostly at high rpm under high load. The reason I don't know if it's the clutch system or the tranny is because of a few reasons.
For one, I DON'T think the clutch is slipping. The car accelerates fine, and if I am on level ground not moving, put it in first and rev it until redline, the car does not move at all. However, when I am driving normally, I noticed that if I push the clutch pedal all the way in, the RPMs don't move at all. They only slightly go down exactly with the car as it engine brakes. I am currently under the impression that even if the car is in gear, when pushing the clutch all the way down, and off the throttle completely, the rps should still die down to rpm. Again, mine doesn't move at all.
HOWEVER, if I clutch in, hold it for even a few seconds rpms don't move. As soon as I pull it into neutral, rpms die down how they normally should. So to me, this means that there is still some load being transferred from engine into tranny, even with clutch all the way in. I know this would make the synchros work harder than they should, which could make things even worse.
Another weird thing is that when going from first to second, even if I shift at around 3000 rpm, not under high load, the shifter just seems like it doesn't want to let me even shift out of first gear. I can clutch in for even two or three seconds and I pull it from first to second, it gets stuck for a moment coming out of first, and again gets stuck and is very notchy going into second.
After the recent fluid change, it has grinded once or twice while shifting into reverse from standstill. I have had it completely lock me out of going into fourth after a redline pull in third. It has literally locked me out of fourth like it doesn't even exist for a solid ten seconds, the whole time i am sitting in neutral, double clutching, rpm all the way back down to like 1500 and then eventually when I blip the throttle it will very reluctantly go into fourth but be very notchy. Also, I noticed that it seems to be notchy and bad for all gears, but sometimes in fourth and up, it will fall right out of gear and not really have an issue going into the next gear.
I also just bled the clutch and it didn't help really at all.
SO my question is do any of you think that I have some sort of clutch issue or is it just the synchros/tranny? Could it be both at this point? I know this post is extremely long but there are a lot of details to get the whole story.
TL;DR: My car shifts really notchy, and sometimes grinds and completely locks me out of up shifting when shifting at high rpm. Just had fluid changed twice to flush everything out, also bled the clutch and it didn't help. Grinded a couple times going into reverse from standstill after fluid change. Car is extremely notchy/hard to shift through all gears, even up into 5th gear. Double clutching doesn't really make a noticeable difference anymore. Even when driving normally, I have to basically force it OUT of 1st when shifting into 2nd. However, while driving I can clutch in all the way while car is still in gear and the rpms don't drop at all, they just behave as if I were engine braking...UNTIL I pull it into neutral (with clutch still all the way in) THEN the rpms fall how they normally should. Clutch is probably not slipping though because acceleration is fine and I can rev to redline on flat ground in 1st gear with clutch in and car doesn't move at all. So do you think I have clutch issue, synchro/tranny issue, or both?
