Hi everyone,
We have an issue with our '13 VT that has been ongoing for several months. The vehicle has spent a long time on several occasions at the dealership and had the battery replaced. Essentially the battery will drain in a few days of not being used. It seems that once it happens the cycle gets worse. I caught it this time at 48 hours the battery was down to 4.8V. Enough to power the start button ring but not enough to crank or even try.
I bought a multimeter and flipped it to 20A, inserted it between the negative terminal and see the current draw sitting around .425A when the vehicle is off. I pulled the multimedia fuse and it dropped to .3xxA. I seem to think the draw should be even lower that this, perhaps .2xx.
Would someone be kind enough to share their current draw when the vehicle is resting? Also, if anyone has input to this I would be very grateful.
Cheers,
Gary
Cheers,
Gary
