41 - 56 of 56 Posts
Discussion Starter #53
Still have a couple of things to do; Torque the brake caliper bolts which I don't have that spec and bleed the brakes which I will do in the morning.
Note .... Factory brake bleeding bolt is 11mm and the speed bleeding bolt is 10mm.
I do have a question . On the brake pad bracket, is the plastic semi ring to be removed ??? The pin appears short. And this would seat it.
gonna have to give us a photo...
Discussion Starter #55
Quick review, driving it for a week. Braking from 100 down to 60 .... Fantastic ! Zero fade . In traffic works like stock brakes only better. I am using Prestone Dot 4 brake fluid , it's works but when the SS brake lines get installed I will be switching to Motul 5.1.
I would highly recommend this for our cars .
Spent about $690 for the Fronts and $214 for the rears. Your prices will vary ! Took a road trip this weekend and the car is awesome. Loaded with about 800 pounds of stuff, it handled great. Even took it off-road 50+ on dirt & gravel. Handles good but got squirrelly at 60 on turns. And the brakes worked great in the dirt too !
41 - 56 of 56 Posts
