1 - 6 of 6 Posts
What's up guys. I have a '16 and my damn bluetooth acts weird. What i mean by that is: when im listening to spotify the song will keep pausing. Similar to a scratched cd except i can keep hitting play to resume. But when it does that the screen button highlights as if i pressed pause myself. Sometimes the screen won't react at all when i try to set up BT. I figure the hot temp in the car or direct sunlight in that instance. What do you think? connectivity issue maybe? Or is it the cabin temp?
My screen doesn’t work when it’s very hot or freezing cold. May be worth cleaning the screen but be gentle and don’t use an ammonia based cleaner like windex, get an ammonia free one.
Reactions: MrNicG
Could be physical interference for the Bluetooth. Even your phone being in your left pocket instead of the right or in your pocket instead of the console can do it.
I considered that but the thing is, a lot of the time my phone is mounted on a vent clip to the left of the screen. So there is maybe 2 or 3 inches between the two.
Rubbing alcohol is also great way to safely clean just about any part of electronics.
1 - 6 of 6 Posts
