1 - 13 of 13 Posts
Vendor
HYUNDAI VELOSTER 18 BOV copy by Boomba Racing, on Flickr
Boomba Racing is proud to announce our VTA BOV second gen Veloster turbo! This is just the start!
-This is a direct replacement to the factory unit, and is proven to be leak free up to 100PSI!
-No aftermarket tuning required. Will work on stock tune or aftermarket tunes.
- This high performance VTA (vent to atmosphere) blow-off valve is precision machined out of aircraft grade billet aluminum. It features an internal brass piston design and is pressure tested to withstand up to 100psi, allowing it to compliment even the most aggressive turbo builds. Spring pre-load determines the pressure differential required across the piston before the BOV opens and releases the pressurized intake charge. Designed to be a replacement for the OEM bypass valve and is available in 4 different colors.
-Installation is simple and all mounting hardware is included
PRE ORDER COMING SOON!
1 - 13 of 13 Posts
