1 - 2 of 2 Posts
Vendor
Combo includes short throw shifter AND weight shift knob!
This short shift lever is built for performance without compromising comfort. It installs easily, replacing the OEM shift lever on your '19+ Hyundai Veloster Turbo with no modifications required to the surrounding console. The re-engineered lever reduces shift travel by 30%, giving you a shorter and more crisp shifting experience as you row through the gears. The shifter is also positioned closer to the driver by half an inch, putting the shift knob in a much more comfortable position, all while retaining full functionality of the reverse lockout.
Shift lever is threaded for M10x1.25. and includes the Boomba Racing weighted shift knob
Weighted shift knobs feature a 270g precision CNC machined brass core for added weight as well as a delrin shell for durability, excellent appearance and ‘temperature management’. A heavier shift knob puts the weight towards the end of the shift lever. This increased momentum while shifting gives you a greater mechanical advantage, allowing for a much more positive feeling throw when rowing through the gears. The delrin shell with laser-etched Boomba logo prevents the surface of the shift knob from getting too hot in the summer and too cold in the winter. These shift knobs make a great addition to your Veloster interior!
Combine with the Boomba Racing Transmission Adapter for maximum reduction!
The shifter and collar itself is designed & manufactured in Boomba's facility, right here in the U.S. and all mounting hardware are included. All shift levers are precision CNC machined black oxide billet steel, anodized billet aluminum and high quality delrin for maximum strength and durability. A definite mod for daily drivers as well as autocross and road racing enthusiast!
Click here to see the product directly on our page!
106693
1 - 2 of 2 Posts
