Thanks to everyone that took the time to answer my questions and Turbosocks for a great product and speedy service.
Hopefully this will help the noobs (like me) out there that thought this would be as simple as buying a boost gauge and the TS adapter. After several trips to the store and a few moments of RAGE I got it done.
Autometer Cobalt Boost Gauge
Turbosocks Flange for BOV/Boost Gauge - Dual Port
OK, Let's do this...
After I found where I wanted the gauge I checked to see if I can run the wiring
Once I confirmed there would be no trouble I began my mission
1) Vacuum tubing: I ran this through what appears to be a large grommet under the dash.
You can't miss it as it has a large wiring harness running through it.
I used a drill bit the same diameter as the tubing for a snug fit.
Once drilled you can run the tubing through easily.
Drilling near the top kept me away from wires under the dash and under the hood.
I then passed the tubing through the hole and pulled all the slack I needed under the hood.
2) Turbosocks vac adapter: I had to acquire a few pieces to get this to function with my particular gauge.
Mine came with 2 barbs as advertised. I plugged one for later use.
The second barb needed to be replaced with a 1/8 male npt.
This allowed me to use the compression fitting that came with my gauge.
Once all my fittings were assembled and on the adapter I installed the tubing onto it. Then
remove the sensor, place the ts adapter with gaskets in place, re install sensor. Simple!
At this time the adapter, sensor and vac tubing are in place under the hood.
3) Boost Gauge: Inside the car I now attached the vac tubing to the gauge and my wires for lighting.
Once I double checked everything I turned on the car and checked to see that the gauge was functioning properly.
4) Lighting: The gauge is clearly marked +/-. I ran my wires to the fuse panel leaving plenty of slack.
Using a mini tap on the fuse panel under the dash I was able to get power to the gauge.
Just to the left of the fuse panel is a bolt. I ran my ground wire to it and secured it with a 1/4 nut.
Make sure you have extra fuses. The stock fuses are too short for the mini tap.
The mini fuse puller I had was also useless due to how the fuses sit.
I raged for a minute then used a pair of needle nose pliers to yank that little bitch out.
DONE!
I thought this would be simple, which it was if you know what you might run into. I thought if I got a boost gauge and the TS adapter I could just install it. I had no idea there would be an issue with how to connect the gauge. I assumed it would all just fit together like Lego. I was wrong and got the help and answers to my questions here. In summary aside from the gauge and adapter I had to get:
Plug for one side of the adapter. You can also use a vac cap. The guy at the store gave me the plug so I used that.
New fitting for adapter to connect the fitting that came with gauge.
Mini tap and extra fuses.
DONE!
