1 - 9 of 9 Posts
I have a 2016 vt when accelerating to go one high way the car boost gauge shows 17.6 pounds but i have no acceleration for a like 4 to 5 seconds and it like its ramping ip to speed . No Eng. Lights ? Its a manual shift .cold air magnaflow exhaust only mods .help
I bet if you run a obd2 scanner you'll find you had overboost condition. Check your clamps and vacuum lines. This can also happen due to fuel cutoff and bad solenoid (either BOV or wastegate)
Boost gauges are not always accurate/calibrated so always use a calibrated gauge or better yet use obd2 readings for boost.
Where is the boost source for the gauge coming from?
You will not get a CEL if you have a leak unless bad enough to cause ~4 psi leak.
Discussion Starter #4
Ok I'm running a Kenwood deck with maestro module ties in to the obd2 plug .give me a readout on the radio .
Is the clutch slipping? Is this in every gear? Video?
Discussion Starter #6
No slippage 53000 on it 2nd to 3rd and thu 4th . Only does it randomly too weird ?
Post a video if you can with the boost and rpm showing.
1 - 9 of 9 Posts
