1 - 3 of 3 Posts
So thus has never happened before. I pull on the stalk to spray and bothwipees move and spray. Then it work normal. Then just the front wiper with no spray. Is it thestalk going bad or did something get wet? Just confused and not happy.
most likely cause. you'll need to pull the airbag and wheel (unplug your battery to eliminate any possible airbag codes). you may get away with cleaning the combination switch contacts instead of replacing it.
1 - 3 of 3 Posts
