1 - 6 of 6 Posts
What do you all recommend? Brand and DOT spec
Run fluid for the most severe conditions you'll encounter from one of the top brands such as amsoil or motul.
This is pretty much the standard for track use and hard touge canyon runs.
This is a dot 4 rating but has the properties of dot 5 fluid.
Most any autocrosser, track day addict, and hard driving fool (like me ??‍♂) will use this for their braking system. ?
i'm using ATE typ 200
that motul is actually cheaper lol once i'm out i may switch. but i clean the brake calipers up and bleed the brakes twice a year... once at the beginning of racing season and once before snow flies.
Hyundai comes with dot 4. Chances are you will experience brake fade from pads or overheated lines then boil your brake fluid. Pads and lines will help better. Good tires also improve brake performance. Last thing i would do is replace all my brake fluid.
1 - 6 of 6 Posts
