My 15 threw the code so I replaced both sensors as they were under a hundred dollars. Well code returned , so my question is, Does this code also represent other problems?
What were the codes? Usually the cam solenoid codes can be resolved with using proper oil, filter, and change intervals. Rarely do they fail but if so use oem solenoids or sensors only.
