HI EVERYBODY,
finally the Veloster Turbo has arrived and i am seriously thinking about getting one, BUT i am a true Sport Car Purist and to me the Stability Control is a Blasfemy... i can pass a Traction Control if i Can disable it at will, BUT a Stability Control of any kind is Totally Unacceptable!
Is there a way to Disable the Stability Control on the Veloster?
And i mean... DISABLE DISABLE!
Not like some Toyotas that you can disable it and once you reach 30mph it re-engages it even if you don't want it, or like the BMW that if you disable it do not allow you do use Cruise Control...
I DON'T WANT A STABILITY CONTROL
So either there must be a button to turn it off, or someone has to clearly say if by cutting wires, the car will not allow me to drive it the way i want to (if you unplug the Bosch ESP Box from a BMW, you can only drive normally and not with Cruise Control.. ABSURD!)
SO... IF SOMEONE HAD THE LUCK TO TEST THIS CAR, I WOULD LOVE TO KNOW THE ANSWER
From this i will decide weather i will want the Veloster or not
