1 - 12 of 12 Posts
HI EVERYBODY,
i am getting ready to get a CatBack Exhaust for my Veloster Turbo... i am inclined with the " MAGNAFLOW 15215 " because i like the Deep Low Note it has to it, BUT i am trying to understand one thing:
i truly love the Stock Big Exhaust Tips of the Veloster Turbo and i would like to get a System that allows to keep them while getting the nice Sound.
NOW... i was looking around OnLine and this is what i found out:
MAGNAFLOW CatBack Exhaust with Stock Veloster Tips Fitting
Automotive exhaust Auto part Exhaust system Muffler Catalytic converter
BUT looking at the shape of this Exhaust, i noticed that this looks more like the one for the Veloster standard... infact all the other sites show only this for the Veloster Turbo:
MAGNAFLOW Veloster Turbo CatBack Exhaust
Automotive exhaust Auto part Exhaust system Muffler Pipe
This not only it has a different shape, but it doesn't show the fittings for the stock Tips... the problem is that both Exhaust appeared when i Google Searched " MAGNAFLOW 15215 "
Is there anyone here in the Forum that has ordered this System and knows if it comes with both types of tips?
Or is there any othe kit that has a nice Deep Sound that has the Stock Tips?
Thank's for the info
CIAO
HI EVERYBODY,
CIAO
The one that does not have the muffler comes with both after market tips and the stock look. Check out UNIQ Performance or Pierce Motorsports in the sponsors forms. They both sell them and sure will give you a deal :D
Plus 1 on the solo. Also got these tips installed as well Vehicle Tire Automotive tire Car Auto part
im deliberating whether to go magnaflow or solo!!
solo is charging an extra $400 to ship to aus so all up its like $1000!! where magnaflow is only $699 from Quniq performance,,,, the $300 i save on that can go towards my ECU reflash :)
I think I asked this same question on veloster.org but i'll ask it again anyways... I have the SOLO MACH 2N1 kit, and really like how those TO27-03 tips look, but can't really drive up from Kentucky to get them installed, did they weld them in place? or clamp them somehow? If I order them would they come with clamps or whatever to install? Solo's site says they are 2 1/4'' inlet, I measured the tail pipes around 2.4''? Just trying to figure out if I can mount them without alot of screwing around... thanks for any info!!
Plus 1 on the solo. Also got these tips installed as well View attachment 3557
ya you did ask this at *****, so I will just answer it here...
The tail piles are 2.5" and slide into the inlet of the the solo tips. I know their website says 2 1/4 but it must be wrong. The tips will need to be welded, which is why Solo didnt include tip options with their kit. They wanted something that a DIYer can do in their driveway. It is something that an exhaust shop can do in under 20 mins. The hardest part of the install was removing the original tips. THey had 6 or 8 nuts, maby 2 or 4 bolts and 2 or 3 phillips screws holding them in. If you remove the OEM tips then take it to a muffler shop they should be able to do it for cheap as it would take 20 min or less.
1 - 12 of 12 Posts
