1 - 20 of 30 Posts
Been thinking of going to a 17 inch wheel and getting some tires with more sidewall to soak up the potholes better. Just got done with a 500 mile road trip and some of the holes and bridge joints jarred my teeth. Anything to worry about ? Don't do it, it'll F'up the car ?
Forgot to mention everything is stock right now. Previous owner must have had a love affair with curbs, all the rims have rash and one is missing chunk out of the lip.
I moved to 225/45r17 tens of thousands of miles ago it's a great ride.
I have 245 40 17s right meow.
Sent from my SM-G950U using Tapatalk
The tire Denver mentioned is the way to go for an all season performing tire. A 16" or 17" should suit you. In that tire I'd go with the 245 in either wheel size or the 255 in the 17" wheel size.
Discussion Starter #5
Thanks guys. Looking at the Drag DR35 on discount tire. Now to find a tires that won't kill me.
Denver I see your running coilovers, would the 245 40 17 still work with the stock suspension ?
I am running 245/40 on 18s on stock suspension... check out Laufenn S Fit tires... great tire made by Hankook.
Discussion Starter #7
Well I decided to stick with the stock rims and tire for now. I'll wait till I can upgrade both at the same time. I'll have more tire options than what will fit the stock rims.
Are those the AVID.1 AV-06 wheels?
I've been eyeing those.
If not, what wheels are those? They look great!!!
Yep! They are indeed, and thank you so much. They are heavy, about 25 lbs in 17x9 42, i wanted gold, but they sent white... kind of a happy mistake as i would have hated the gold.
Discussion Starter #10
Would that set up work with the stock suspension ?
Sent from my VS990 using Tapatalk
Probably way better than being lowered. Haha.
Discussion Starter #12
Just worried that it would look weird without being lowered.
Oh that is a good though, and yeah you would have a lot more wheel well to fill.
Discussion Starter #14
Guess I'll stay with 18's really wanted the white avids but think the 9.5 might be to much.
Depending on your offset
Discussion Starter #16
Actually I don't think it'll be that bad. Been playing with willtheyfit and others and the numbers aren't that far off.
Discussion Starter #18
Dude our car has 3 doors... dont worry about weird looking rims and tires...
But we can only have so much weirdness.
Discussion Starter #19
rspec what rims are you running ?
Discussion Starter #20
Nevermind rspec I'm a frigging idiot. Says what you're running in your signature.
Reactions: DenverVeeTee
1 - 20 of 30 Posts
