Check the crank pulley..........lol
That's terrible......but funny!Check the crank pulley..........lol
I hear something similar when accelerating from 20-40mph but it stops after 40.... its really weird... I thought it might have been the sunroof, but not sure as it seems to be more of a vibrating/buzzing noise.That's terrible......but funny!
OP, I hear a chatter/rattle that sounds like sheet metal vibrating against something. I really only hear it when I'm pulling in the driveway (slow speed, feathering the clutch), so I pay it no mind though.
Yup, same here. However it only happens at about 1600 RPMs. It sounds as if there is a loose heat-shield or a piece of metal rattling. It sounds as if it's coming from somewhere below the center console, it can be heard better in the back seats. I took it to Ourisman Hyundai in Laurel and they looked at it for about 3hrs and could not find the cause. And they were not able to reproduce the sound every time. I haven't heard it in a little while now.I am getting a intermittent chatter/rattle from rf under hard accel from stop, rolling slow, sounds almost like an axle noise, anybody else have this ????
Are you changing the oil yourself? Are you using a cheap oil filter by any chance?Sounds like I am getting a similar sound. Mostly it's when I first start the car up and when I turn the tires it almost sounds like hard plastic crinkling. The sound goes away after the car is warmed up or at higher speeds. This started happening around 5k miles.
I'm getting a similar noise. At least i think it's the same noise. Mine is heard when first accelerating from a dead stop or after being in reverse. It's like a click or a clunk. Did you ever find out what it was on your car?
