Flash tuning hardware. Chipsoft J2534 Lite and the other little dongle you need too. I'll even throw in the USB hub (my laptop only has one normal USB port so I needed the hub).
Purchased from 845 Motorsports.
mine was a 2016 but pretty sure this works on any gen 1 VT 13-17 possibly newer.what year
nevermidn thanks I got a second genmine was a 2016 but pretty sure this works on any gen 1 VT 13-17 possibly newer.
FYI, This can still work with a gen 2 VT with additional equipment and another module on the USB dongle. There is no OBD2 flashing though. Has to be flashed through the ecu itself which can be done while leaving it in the car.nevermidn thanks I got a second gen
what do I need to get ?FYI, This can still work with a gen 2 VT with additional equipment and another module on the USB dongle. There is no OBD2 flashing though. Has to be flashed through the ecu itself which can be done while leaving it in the car.
Module 61 for pcm flash on the USB dongle and a bench flash box with either wires to hook to ecu pins or wired to an ecu harness that plugs in. Will also need a way to power the bench flash box. I typically use a drop cord to a wall outlet or a power inverter.what do I need to get ?
