After months of parts replacements, cleaning, and troubleshooting, I think I've isolated the issue to temperature. Potentially temperature inside the fuel tank. It seems like the fuel is getting too hot and there's some sort of safety cutoff that happens. I came to this conclusion because the the issue with the car cutting off completely disappears when you add more gas to the tank. It also seems to fix the issue for different lengths of time depending on how much gas you put in it.
For instance: If I'm under half a tank, and I put in a gallon of gas, it will fix the issue for about 30 minutes. If I'm nearly empty and fill it all the way to the top, I get a few hours of driving before it cuts out again.
Is there a way to check fuel temperature? What would cause the gas inside the tank to heat up? And do you guys think I'm on the right track, or could it be something else?
