1 - 7 of 7 Posts
What do your guys VTs idle at when cold started? I have noticed mine ideling at like 1300/1400 RPM for a few seconds and then dropping down to normal?
Vendor
as the other thread says.. it is to get everything sorta jump started and the oil pumping/warmed up..
Mine goes to like 1500 rpm for about 5-10 seconds or more.. then goes down to around 1000 before it settles to idle..
Boosted cars always run less boost when cold to be safe.. It is a safety mechanism, not a glitch..
Depending on the temp and conditions at the time, it may idle higher for longer or settle down sooner than normal..
So basically, on a really cold Canadian start, that's pretty much what a NAV feels like? :D
Vendor
haha, not that bad, but you really shouldn't flooooor any car before it is a bit warmed up or you could do some damage over time.
1 - 7 of 7 Posts
