1 - 6 of 6 Posts
Hi, I am new to the forum. I have a 2013 Veloster Turbo Auto with 75k miles. I just recently noticed this (pics) on hose that connects the radiator to the engine. It's all dried up and I don't know when it started since I don't drive my car much since 2019. I drive the car probably a couple of times a week and short distances under 10 miles. The coolant in the reservoir is just 1/4in above the L mark after driving it and warmed up; if this info helps.
Has anyone experienced something similar? Do I have a leak?
Your input would be much appreciated! Thanks!
Automotive tire Steering part Motor vehicle Steering wheel Automotive design
Motor vehicle Automotive tire Hood Automotive lighting Automotive exterior
Possibly very small leak. Clean it well, fill coolant to the F mark, crank the car and let it idle until the fan comes on. Then drive a few miles and check the hose for leaks again. You may or may not need a new hose. Sometimes cleaning the oem hose or moving it a little fixes any leaks.
Thank you trdtoy, I'm going to give this a try today. A silly question, can I fill the reservoir with distilled water or should I get the Hyundai OEM coolant? I live in Southern CA, if that matters. Lastly, when I let the car idle, do I need to keep the reservoir cap off to let any possible air out?
Yes fill up the reservoir to the F mark with distilled water is fine. Do this after you try to fix the hose as you will lose some.
If the problem persists, let me know, I know a mechanic in So-Cal that works on our VT's. He fixed my head gasket and many others
Sent from my SM-N960U using Tapatalk
1 - 6 of 6 Posts
