1 - 20 of 22 Posts
Land vehicle Vehicle Car Engine Mid-size car
My custom SRI used 1/16 inch thick Stainless 3 in tube ( cant weld aluminium very well ). I put the filter down and to the left more then the Injen to leave room for my catch cans. Then I'm gonna hide them and the filter with a box over top to kinda keep the stock clean look. I powder coated it myself Wrinkle black and baked in oven. If you never done this before kick the Gf/wife/kids and pets out of the house because it stinks bad.
Thats pretty clean. Thinking about doing something like this myself. No point in buying a name brand SRI or CAI when a custom diy is so easy.
How much did you spend all together for the materials, iif you don't mind of course?
125 for everything but u need a way to powder coat too i had that
That's not too bad. But with the discount codes that have been flying around I'd rather spend an extra $50 on a proven product with a warranty. Good on you though man, looks good :)
Discussion Starter · #16 ·
You'd really want aluminum or abs plastic on the cold side. Better heat transfer, stainless holds heat more, thus the need for powdercoat. Props to the fab work though...
I will highly disagree with you. If the car was NA maybe heat a issue but it goes through a 1000* Turbo then cooled b4 the intake manifold so it don't matter what metal or coated or not
· Vendor
looks pretty good! good work!
Also going to say that the metal, while under load (when the CAI/SRI matters for power) the air temperature is not going to be significantly affected by the intake piping material.
1 - 20 of 22 Posts
