1 - 4 of 4 Posts
2013 Veloster Turbo
Cylinder 1 is misfiring on my '13 VT and I've read that the spark plugs might need to be replaced but when I tried to buy new plugs and such at the parts store I was told that I needed a coil pack and i could only get it from a dealership. I'm pretty confused. For refrence the cylinder started misfiring after I acclerated a bit too quickly and now i can't accelerate for crap now.
Welcome to the forum
Read on this forum you will find your answers. You will most likely need new OEM coils(I have some) and proper plugs(this will be determined by mods and condition of your current plugs and what plugs you have.
2013 Veloster Turbo
Thanks! I replaced all the spark plugs and one coil and it solved the acceleration issue. Check engine light is still on so I'll likely clear the code and see if it pops back up after i've driven it some.
Best to replace all the coild with proper OEM coils and replace all plugs with proper plugs and gaps. And by proper plugs in the 13 does not mean the OEM plugs as they're crap compared to the 16+ cars.
1 - 4 of 4 Posts
