Does the VT have standard DRL's? If so, can you remove a fuse or somehow get them to be on with ONLY the LED's on instead of the whole headlight?!? If you have to turn them on manually every time you're in the car then that solves it right there.
A curious mind would like to know... Thanks in advance to the feedback!
