1 - 14 of 14 Posts
I just got my (Black) Veloster Turbo and I love it! It has the blue trim interior and it is just sexy! I'm not even sure if I want to do anything custom to it just yet. I definitely want to put window tint on it (20% all around).
I was also thinking about a...
Cold Air Intake.
Blow off valve.
Enkei Rims (Black)
Blue Neons.
Intercooler (possibly)
I just want to see if any has done anything yet so I can get an idea...keep me posted!
#teamhyundai
Reactions: dascrow
Take a look at Turbosocks posts. He has transformed his VT. Looks awesome!
Vendor
I have done a handful of things already and have a couple more to do..
I have done a DIY front lip, NGM lowering springs, bumper claws, wheel spacers, XXR 530 wheels, custom SRI and Forge BOV.
Things that still need to get done are muffler replacement/removal, HIDs, window tint, night shaded tails and plasti-dipped 'H' emblems.
Turbosocks, which Forge BOV did you get? Looking at your pics and the Forge site, I'm going to guess the FMDVHGA. I'll hopefully have my VT in a few months when the dealership here gets one in for me.
Vendor
yep, thats the one.. get it on ebay though.. 20$ cheaper :p
turbosocks what possible problems were you talking about after you installed you bov
Vendor
I just threw a CEL ( I think due to the higher pressure spring ) for the BPV which doesn't seem to affect the driveability of the car.
Well, I don't know what it is but under WOT and higher boost it sounds kinda like a flutter (almost like surge limit sounds) I don't know if they are there stock and you can't hear it or what. Obviously with the SRI it is a lot louder.
did they not have the same spring rating available? i would prefer to stick with the same spring rating
Vendor
the BOV is for the Gen Coupe.. I would never use the stock spring rating in a BOV, it defeats the purpose. The stock spring rating is something like 4lbs I think. I just think the medium pressure spring made the car angry and threw the CEL. I put the higher pressure spring in to see if it would alleviate the sound I heard at higher boost (thought it was possibly a leaking BOV from the pressure)
did it eliminate the sound? did the CEL go off? also what spring rating are you running now
Check this site out, it may be a little cheaper, I bought mine there:
Hyundai Genesis Coupe performance parts at GenRacer - Performance parts for the Hyundai Genesis Coupe
I’m not sure if I’d buy it used (could receive a leaking bov) but you may find some new ones too…
Turbo, I’d check your crescents and make sure its correctly aligned if it sounds like a flutter. I was going to tell you when I saw your video it didn’t sound that loud compared to my FORGE BOV that was on my Genesis Coupe. Make sure you have the moon crescents aligned and if it looks like its impossible to align because of the nipple at the end you can actually loosen that up and spin that to another direction. Most importantly it needs to be aligned, you don’t want a compression surge at all so just check that out when you can.
FORGE BOV springs
GREEN (up to 14 PSI) = STOCK BOOST
YELLOW (15-22 PSI) = Any more Boost run the Yellow
Vendor
the ebay one I bought was brand new, just from a different vendor.. Buying used isn't bad, especially with the forge.. It is so simple there isn't really anything to fail and the o-rings are cheap to replace!!!!
everything is definitely installed correctly.. would be hard to install something so simple wrong.. It doesn't sound like the BOV flutter, sounds like turbo 'flutter/surge'
stock boost in the VTurbo hits up to 18lbs which is why I used the yellow but the ECU doesn't seem to like it to much.
compressor surge from the BOV not opening really isn't bad but surge from hitting the sir surge limit line is bad which is why I was stumped when I heard the sound from what seemed to be the turbo itself ON WOT, not during shift (where you typically hear the unharmful flutter/gobble)
I am using the yellow spring now, going back to green when I do my HIDs. I doubt the sound will go away but the CEL might. If the CEL doesn't I will just clear it with my scanner.
Let me know what the results are when you go back to the green spring. I'm curious to know if your CEL goes away before you clear it with the scanner.
1 - 14 of 14 Posts
