1 - 20 of 37 Posts
Automotive Lighting Experts
2012-2016 Hyundai Veloster Turbo Multicolor LED Boards
Upgrade your Veloster Turbo's factory DRLs (Halos) with these drop-in RGBW multicolor replacement LEDs! These modules are a direct replacement for the factory panels that light up the ring. Your order includes two total ring-shaped boards, to replace the OEM boards on both the driver and passenger side, as well as the required drivers.
From the factory, the DRLs in the headlight are illuminated by small 1210-size white LEDs. Our new replacements are a direct fit, and have 5050-size RGBW chips instead of the simple white LEDs. This allows for full color control, as well as a pure white color for everyday use.. You don't have to align and fasten LEDs- this is an OEM-grade solution. Just remove the old panel, and ours fits directly in place, with patent-pending fit and finish.
Made in USA, the replacement panels utilize RGBW LED chips. Each one illuminates with red, blue, green, and 6500K white. The multicolor function allows for full multicolor control using any standard common-anode RGB or RGBW controller (not included).
Remember, this product is not just RGB- it is RGBW! That means there is an LED chip that is specifically white in color, right next to the standard red, green, and blue chips. By using an RGBW controller rather than the standard RGB, you can activate and control the white chip independently of the colors. This provides a much more uniform, pure, and bright white color than the traditional method of combining all RGB signals.
To drive the LEDs safely, a new constant-current driver is included for each set, for high reliability. You will also need a standard RGB or RGBW controller. Controllers can usually be powered by any standard 12V source. We recommend connecting to the parking light signal, so this module lights up when the parking lights or headlights are on, or to the factory power input signal.
There is a standard RGBW input plug (5-pin) to connect to your RGBW controller. This connector is plug-and-play with Diode Dynamics controllers. We strongly recommend the use of Diode Dynamics controllers with this product, for ease-of-use. However, you can connect any standard RGB or RGBW controller by cutting the pins off the connector end, and connecting them to your controller, in the required color configuration, as dictated by the controller you use. This does not void the warranty.
Professional installation is strongly recommended, as the factory headlights must be opened in order to replace the LED panels.
All Diode Dynamics products are backed by a 3-year replacement warranty.
If you have any questions, please don't hesitate to post, PM, email [email protected] or call us: (314) 205-3033
*PM us for the free-shipping code* (U.S. forum members only)
Thanks for looking!
Nick C.
Diode Dynamics
Why not the LED's at the bottom too?
That's a separate location, that utilizes a ribbon-style circuit board vs. a PCB like the "halos". We may introduce a replacement in the future, but the RGBW LED Board replacements are a direct fit for the halos.
Nick C.
If you send me the blue ones ill definitely be a model :)
1 - 20 of 37 Posts
