1 - 17 of 17 Posts
I've been searching for a thread that covered painting the inserts black on the stock VT wheels, but couldn't find one. For those interested, here how it looks. I like the chrome inserts, but found that I liked the wheels better when the chrome picked up a dark reflection. I've always liked the tech wheels with black inserts...I know this is a little different, but I'm pretty happy with the results.
Thanks., I guess it took about 3 hours. I was only able to take one wheel off at a time. And, I put each one back together as soon as I could handle the inserts...carefully. Very easy to do.
I like! This may be something to do to our Black VT to make it "just a little bit different" than the rest. :) How many coats did you use and what product did you use? I haven't take a wheel off to see how the inserts are attached, so I'm curious... is it done by screws clips or what? Again... it looks great and really goes well w/ the silver paint and black plastic accents throughout the car's design.
I used one can of plasti-dip black, and was able to get 3 to 4 coats. The inserts each have 3 small Phillips head screws holding them on. The center section just pops out by pushing from the back. I sorry now that I didn't take pictures of the process.
Thanks, bud! Sounds easy and inexpensive enough!
· Moderator
Looks good. I was think of doing it too. Ive never worked with PD before. Does it require and prep or a clearcoat?
From my experience I did not need a clear coat, unless you like that gloss look better of course, but the normal PD is pretty sturdy-ish ;).
Prep that I did was just to clean the area with a simple green and water mix, then alcohol wipe to get rid of any and all contaminants that may still be there like grease, etc.
However, if you're prepping a painted surface, I do not think alcohol is the way to go bc you could possibly damage the oem paint. ~my 2 cents~
You should not have a problem using alcohol to prep for Plasti-Dip.
Laquer Thinner or Acetone would likely damage the factory finish.
I haven't tried either and wouldn't recommend them.
But I used alcohol to prep the Hyundai Logos, and the chrome grill and surround on my NAV, as well as my previous Toyota Tacoma with no issues.
I just made sure to wax the area when I was done since I'm sure the Plasti-Dip took the wax off.
I was thinking of doing the same thing to my VT, only using White Plasti-Dip.
If only my VT would show up...
Been 5 weeks already...
Just got an email saying it may be another 5 weeks or more...
No White Ultimates with 6 speed Manuals anywhere near Chicago...?
Discussion Starter · #13 ·
I simply used alcohol to prep the parts before applying the PD. I started this as an experiment to see how I liked it, that's why I used the PD as it would be easily removed if it turned out bad or I didn't like the look. I bought a can of the glossifier, but kind of liked the flat look better. If I have any durability issues, I'll likely remove the PD and prep the inserts with light sandpaper and apply something like duplicolor. Time will tell....
I used a Carbon fiber vinyl wrap on mine and on the matte gray bars on the front and sides. I expected it to take only 2 hours----Then 8 hours later i was completed. It looks really really nice, you should check it or give it a try. The vinyl wrap that is like 10 bucks at auto zone works rather well.
Discussion Starter · #17 ·
Haven't had much luck with the vinyl wrap....pretty tough. Post some pictures of what you did, we're all looking for ideas.
1 - 17 of 17 Posts
