DIY Add Two Tweeters to the Rear
2623 Views 5 Replies 2 Participants Last post by  drako1830
9
For taking out the rear paneling please refer to my other DIY and then come back to this one. http://www.velosterturbo.org/forum/veloster-turbo-diy/894-diy-get-driver-side-rear-speaker-sub.html
Items need to do this:
A set of tweeters, pen, razor or hotknife and about 20-30 min
Vehicle Auto part Car Tire Automotive wheel system
I used the two top rear panels and measured about 2"1/4width and 3"3/4 high on both of them. Even though there positioning is differently spaced within the car at least it will be in the same location on the plastic… So I used a basic pen to mark my location for them as seen…
Button Hand Finger Fashion accessory
I used the ring of the Tweeter to trace the circle to use the razor to cut.
Input device Technology Electronic device Hand Auto part
Tightly press the ring where you like the tweeter and trace it.
Floor Metal Flooring
It’s easy to cut this plastic as its really soft, I just press it into the plastic and wiggle it back and forth and pull out and start right next to the pervious spot. I KNOW SOMEONE IS GONA SAY USE A HOT KNIFE… IT’S MY PREF AS I FEEL I HAVE BETTER CONTROLE THIS A RAZOR AND LESS MESS AND TIGHT FIT.
Metal Silver Circle
Shown cut and just remove it
Red Auto part Vehicle Car
Now take the ring and try to place it into the hole and More than likely it won’t fit and all you have to do is trim around the edges and keep placing the ring on it to see what needs trimmed and it fit great
Vehicle door Bumper Auto part Automotive exterior Windshield
Metal ring that go’s on the back to hold the tweeter in place.
Show the nice smothness
Gun Trigger Firearm Airsoft gun Airsoft
Both done looking great!
1 - 6 of 6 Posts
3
NOW YOU SAY WHAT ABOUT THE WIREING OF THEM?????????
Well the DS one will go stright to your new DS rear speaker as i did it this way...
Auto part Vehicle Car Engine Rim
Metal
Auto part Metal
As for the tweeter on the PS rear i will show pics of how i ran it stright down to the OEM AMP and tapped into the wire for the PS rear door speaker
Thos pics will soon to come...
Lol , you did the same thing i did and ran the wire thru that little hole .... i got worried when i realized that little hole was the panel fastener hole, i need to re-do mine as i am worried the wire is going to get pinched and short out.
View attachment 1143 View attachment 1144 View attachment 1145
I got the subs going in tomorrow, all the door speaker install stuff i got is the same as you so I wont bother posting it. Had no idea what the polarities on the stock wires were so i just matched them based on the design of the white clips ..
Well as fare as the sub i havent had time yet to measure everything but i am doing a rockford for sure and im useing a pioneer digetail amp and next is to figure out the wire setup on the oem amp ( if you know it let me know) also i found a box under my driver seat so not sre what that is as well.
2
Heres the look at the finished and installed...
Vehicle Car Rim Wheel
Vehicle Car Wheel Automotive exterior Auto part
1 - 6 of 6 Posts
