1 - 1 of 1 Posts
These are all the parts I have ordered. Re-using the oil drain line and coolant lines. I already have the new turbo but I want to make sure I have everything I need before I tear it apart. Any insight would be great.
Coupling gasket
Manifold gasket
Oil feed tube eye bolt
Oil feet tube washer
Oil feed tube
Oil feet tube gasket (upper and lower)
Oil return tube gaskets
Valve cover gasket
Oil pan
Extra manifold studs in case a few break
Coil packs (4)
Oil pan
Water hose assembly washer
Water hose assembly bolt
Coolant
HPFP o-ring
1 - 1 of 1 Posts
