Thanks for the Tip!ECU tune all the way! The better tuners will get you more power than these with much more reliability/safety. I'm tuned by Sxth, so I'd highly recommend them but I'm sure others can chime in with some results from some of the other tuners out there
Any tuner can have a tune on a spare ecu if you want to revert back to stock. Or another option to avoid the hassle of swapping the ecu and more options on tunes at hand would be having remote tuning hardware/software.I went with Lap3 because they're not touching your original ECU. They send you another one that you plug in. If you need to get revert back for any reason, you've still got your original.
I was considering either one of these tunes? Is it even worth it? what set up does everyone have that has a tune on their velos?
Suggestions?
This post is from June, 2018.I was considering either one of these tunes? Is it even worth it? what set up does everyone have that has a tune on their velos?
Suggestions?
