1 - 7 of 7 Posts
2014 Veloster R Spec
I bought the Eibach springs a few months ago but I've been stalling to put them on since I also need shocks. Any recommendations?
OEM will work with springs. Otherwise you'll be spending $ for an upgrade.
Reactions: JillCastillo
I went with Koni struts & shocks. Have had them on now since 2017 and still like them.
Koni yellows on my Mazda 3, huge improvement. If I ever get time they will go on the Veloster as well.
love the konis on the back. biding time for rspec springs and a fresher set of fronts so i can do the inserts.
Also KYB has both the rear, and front (front are a complete strut, no cutting like Koni), for VT in the gas adjust series.
koni or kyb as mentioned here would be the way to go but like I mentioned before $. If you want it for better performance then do spen the $. If you want it just because or someone said you need something different when lowering the car then just keep oem.
1 - 7 of 7 Posts
