So I installed my subwoofers and amplifier this weekend, and have a small problem.
I did not touch the head unit, rather tapped into the rear positve and negative left and right speaker wires at the stock amp as well as the ACC wire for my antenna wire. I used 3M red connectors so there was no cutting of the stock wires at all. Ran all the wires, power wire to the battery with fuse, ground wire to a bolt in the hatch, ect.
One thing I had to do that Im not familiar with was attatch RCA plugs at the end of my input wires that plug into the amp. Pretty simple though.
Hooked everything up and turned on the stereo. Problem is that with BOTH rca plugs in the amp, the subwoofers dont work, and neither do any of the rear speakers in the car. Plug just one RCA input into the amp, and everything works fine.
I thought maybe I screwed up the RCA wires so I cut them off and rewired them, sautering them this time. No change. Asked a few people more experience in car audio than myself, and they dont have an idea either. Thought I would ask you guys.
If anyone has any ideas please let me know. I dont like doing things "half @$$"
