1 - 10 of 10 Posts
For about a month now I have been having some serious issues with my 2013 VT (68000mi). Out of nowhere I started having rough acceleration at about 70% throttle. The issue is best described as the engine sputtering. I have been convinced that this was not caused by a misfire for a while, since the ECU has not kicked any misfire codes or even flashed the check engine light when it was sputtering. Until today, when I got a cylinder 3 misfire code and random/multiple cylinder misfire detected. I now believe I might have a bad coil or plug, since before this started happening I would occasionally have a rough idle where I drop from 700 to 500 rpm randomly. Less than 2 years or 10,000 miles ago I had to replace all my coils and plugs from the same issue. Since I did not know what the issue was at the time, I had a Hyundai Dealership replace the bad coilpack with an OEM one (which was extremely overpriced because dealerships). And because I wanted all of them replaced at the same time, I replaced the other 3 with Delphi GN10683's and replaced all of the plugs with NGK Iridium's. Shouldn't they be lasting longer than this? And what can I test to rule out if it is fuel, coils, or plugs? The picture I attached is what every plug looked like. How can I test their gap?
Microphone Audio equipment Gas Auto part Metal
Mods I have done to the car:
• AEM Cold Air Intake
• Aftermarket SXTH Element High pressure fuel line
You need to run 4 new proper OEM coils, 4 new OEM plugs from a 16+ VT and gap to .028", and run 91+ octane fuel.
If you need coils they can be bought for $200/set and plugs are around $60/set.
Welcome to the forum.
I think it should also be noted that I have been having code P0441 (EVAP) being set off at the same time. I thought this was my loose gas cap, so I got it replaced but the code is still being set off. Could this be a fuel issue?
If not gas cap then will be the evap solenoid above the throttle body or the CCV near the gas tank under the car.
Considering the other information, 100% no.
After getting the P0303 code ealier today, I have pulled the coilpack and swapped with cylinder 1 to see if the code would follow. Ran the car for a bit and it kicked the P0303 code again. It must be plugs, which I am going to be replacing tomorrow. What is the downside of going with other brands vs OEM if I make sure they are gapped to .028" spec, such as Bosch or NGK?
Do as I said in post #2 if you want to be trouble free for a long time.
You want all new of both coils and plugs or you will have issues and sometimes without a CEL.
1 - 10 of 10 Posts
