1 - 10 of 10 Posts
Arguably the biggest reason for this is compression ratios. The turbocharged 1.6T has a lower compression ratio to account for the fact that the cylinder will already be pressurized by the turbocharger, which is then compressed even further by the piston as it travels upwards. Simply slapping a turbo onto an otherwise stock NA 1.6 would introduce far higher cylinder pressures than the engine was ever meant to handle. You'd have to upgrade so many of the internal components to handle the stock compression ratio that it's simply not worthwhile to do so.
There are other reasons that it won't work, of course. But if, for some reason, you were dead set on turbocharging a NA engine, just know it'll be cheaper to buy a 1.6T outright than to modify yours to work.
thanks for the insight! i was just curious because of the price difference
so now what about the ‘16 rspec engine? i purchased one last night but the parts store said it wouldn’t work. i got told the ‘16 vt would work on a diff post but what about the rspec?
Are you asking if the 16 Rspec can be turbocharged, or if you can swap it into your vehicle?
The Rspec should already be turbocharged.
You will need more than just the actual engine to swap it into a NA. You'll also need the wiring harness, ECU, an intake and intercooler just to name a few.
It will work but there's more to it than just dropping the engine into the bay.
Custom axles are needed, ecu from a turbo motor, and the transaxle as well.
This also. Unless you have the mechanical skills, electrical skills, and an endless wallet it can be done and work perfectly.
Ask me how I know although the wallet has some emptiness every now and then. 😂😁.
1st gen Veloster turbo prices are down for good used cars. That would be your best bet and still be happy with it.
Good luck. 👍
Discussion Starter · #9 ·
well what i was asking was if the 16 rspec engine would drop in to the 13vt but it seems like it does. Just got the engine delivered last night and dropping it in tonight
it will work fine just be cognizant of different connectors and sensors, ie. coils are most important.
1 - 10 of 10 Posts
