1 - 20 of 20 Posts
I road trip a ton in my VT. More than half of my 90,000 miles is from long highway drives at constant speeds for hours at a time. This past weekend I encountered something that I haven't before with my VT.
I stopped for gas after about 4 hours of driving and checked the oil. Luckily I did because I was nearly 3 quarts low. A quick investigation and I couldn't find any evidence of any leaking. I was just under the car a month ago and everything looked good. Engine temps were good, car was running fine, everything was smooth, no issues. So to be that low on oil seems really strange. That seems like I've got some serious issues if I'm burning that much oil. Unfortunately I don't know if it was just over the course of this trip, or longer since I haven't checked it since changing it a month ago.
Discussion Starter · #3 · (Edited)
Always done dealer oil changes, because it's cheaper, faster, and an easy paper trail for warranty issues. To my knowledge they use Quaker State 5w-30 Synthetic. This last change I did myself, because I had the car up for a bunch of work and figured why not. Used the same quaker state 5w-30 synthetic the dealer uses, and Bosch filter to be as close to factory spec as possible. Overfilled at first, drained extra. Made sure it was right at the full line before the car hit the road again. Clocked 2,000 miles since that oil change on this trip.
No Catch cans. Breather is vented to a filter though. I have the old style TS intake (Waiting on my 3.5' from SoCal) which didn't have a breather port.
· Premium Member
First mistake was not using an OEM filter. Please get one on the vehicle. There are TSB's out there stating they need to be used. They are very cheap from the dealer, around $7
3" Intake, Magnaflow exhaust, tork pipe, cold pipe with HKS BOV, XPVS, updated the manifold boost sensor, no tune. Recently changed plugs with NGK's and replaced coils with OEM Hyundai coils. Breather filter could use a change, and no visible leaks that I could see.
· Super Moderator
2014 Veloster Turbo Manual
FWIW if the dealer charges under $40 for the oil change, it's not synthetic.
Discussion Starter · #9 ·
$44 for a synthetic oil change at the dealer.
· Super Moderator
How would the dealer be cheaper than doing it yourself?
i cannot speak from his experience but if you factor in the oil change + materials, fluid top-off, vacuum and wash that my dealer does, it's cheaper (by my hourly wage) than if i took the time to do it myself. but i also do conventional oil, quaker state.
Reactions: Boots Ylectric
· Premium Member
That is a super cheap full synthetic oil change. Are you sure its full and not a synthetic blend? How often do you go for long road trips? How many mile son the VT and what year and trans? Possible your burning it.
· Super Moderator
I’d agree, synth at my dealer is $78. Just a hair less than getting the synth at VW for our Jetta lol
Discussion Starter · #13 ·
That's a good question. I was under the impression it was fully synthetic quaker state. I was going to start doing them myself soon, because my warranty is about up anyway, and hearing a lot of people swear that these cars need better oil in these cars than what the dealers use. I'm at just about 90,000 miles on a '13 manual. Road trips are a usually a monthly sometimes more frequency. Car has always been great for them.
· Administrator
Not using oem filter, using mediocre oil, creating pressure in the crank case with a filter on the breather, and operating under harsh conditions all do not help things out.
· Premium Member
Yea I would recommend using Amsoil 5w40 synthetic and an oem filter from here on out. We use it on every 1.6 Hyundai Kia we work on damn near and never have issues. We sell oil change kits on our website if you wanna pick one up. damnfatsdd.com
I’m having the same issue at the moment if you could help, I have a hyundai veloster turbo 2014 with 139,400miles I had it serviced not too too long ago at grease monkey and they put in Synthetic blend 5w-30 I checked my oil this morning if it was practically empty, oil change sticker said I wouldn’t need an oil change until 143,000 miles. The car is completely stock with brand new spark plugs and coil packs. Check engine light is on throwing codes p0301,p0302,p0303, and p0272. The car drives super smooth and notice no issues when driving whatsoever so I don’t know what the issue is here and why I would’ve consumed that much oil so quickly.
· Super Moderator
any leaks? coolant reservoir a funny color?
do the plugs have oil on them?
1 - 20 of 20 Posts
