1 - 5 of 5 Posts
You might see it on IG under @pedalsandpinheads, but that's still my car and...me. :) Here's a placeholder for the stuff I've installed and I'm installing, as I'll put in part numbers and such when I build this thread out.
Takeda aFe CAI
Magnaflow cat-back exhaust
Significant sound damping material because of Magnaflow exhaust
Pierce Motorsports catted DP
Pierce Motorsports dual-tube strut tower brace
MAC BOV/Diverter solenoid
SXTH Engineering MAP Sensor/Vacuum Port Adapter
SXTH Engineering OCC
SXTH Engineering shifter cable end bushings
Hakari LED High Beams
Valentine One (hardwired to unused fuse socket with fuse tap)
Those are either on it or are on their way (such the DP and strut tower brace, where the wrong one was sent). Now, for the stuff I'm looking to get...
TSW Geneva 18x8 +35 in Matte Grey
Michelin Pilot Sport 4S 235/40-18
LAP3 Tuned ECU (alternate spark plugs and EBCS as required)
GFB Respons diverter valve
Quaife LSD
Eibach springs
Eibach adjustable sway bar end links
Adjustable rear sway bar (not sure of which brand)
KDMTuners CTS-V front brake set conversion
Alternate seats (possibly Sparco or Cobra CF/Composite)
104196
Discussion Starter #2
The TSW Geneva wheels came in...
And are on...
Discussion Starter #4
Wow, I haven’t been to this forum in a while. Sorry about that. If you didn’t find your info elsewhere, they do protrude at stock ride height, and I haven’t lowered it yet to see how much of a change it is (I imagine it will be slightly worse without camber change).
I have the exact same car & color except it's 2020. Those matte grey wheels look sick! Thanks for posting them. You've convinced me to steal my winter matte grey wheels from my Elantra GT N Line and put them on my R-Spec next winter!
1 - 5 of 5 Posts
