1 - 5 of 5 Posts
2016 VT
Hey all, having an issue with wheel rub, 2016 vt, running 18x8 with 40mm offset (A lil wide I know, I know, I like poke fitment) although I know adding camber, lowering tire profile, or just going back to my stock rims would help, I want to keep the current fit, besides these I need outside the box solutions, quite simply put im talking like remove the fronts and use truck bed liner to rust protect ,these liners have been pissing me off since I got the car🤷‍♂️
Anyone have any other ideas or solutions for this issue? Also thought of maybe removing them and doing some modifications to the OEM liner.
Any ideas helps, thanks in advance 😁
Automotive tire Tire Tread Synthetic rubber Automotive wheel system
Tire size? Suspension specs? When and where are you rubbing?
you suggested what to do however camber isn't really going to fix it just change where it rubs. trust me i know.
you're going to need to remove the fenderliner or change the tires.
Reactions: Intulect
2013 VT
these shitty liners will tear at the slightest break from OEM, I swear lol. I've replaced them myself 3 times, and I'm only dropped 1" in the front with 18x8.5 +30, and this has been my most aggressive setup yet. I have them pulled away from the tires and toward the bumper with some bolts/nuts/zip ties, but honestly, f*ck these things man. Or run a less-than-ideal OEM setup :/
1 - 5 of 5 Posts
