1 - 20 of 228 Posts
Automotive Lighting Experts
Veloster Turbo Footwell LED Kit
Looking to add a little color to your Veloster's interior? Diode Dynamics' RGBW Multicolor Footwell LED kits are the way to do it! By adding Diode Dynamics' LED strips under your dash, you can add RGBW color-changing ability to your Veloster's footwell area.
This kit is not just RGB, it is RGBW! That means there is an extra integrated LED chip that is specifically white in color, right next to the standard red, green, and blue LEDs. By using an RGBW controller, you can activate and control the white chip independently of the colors. This provides a much more uniform, pure, and bright white color than the traditional method of combining all RGB signals.
Our Bluetooth Controller will allow you to choose any color under the sun, including True White, directly from your phone! Our mobile app includes a wide variety of features including strobe and fade effects, preset colors, Camera Match, Music Sync, and much more. Our controller will also allow you to adjust the brightness of the LED strips. Any time you power up your strips, they will default to the last color that was previously selected.
These LED strips in this kit are highly flexible and waterproof. They feature high-density LED chips for brighter output and barrel-style M8 connectors for a secure connection.
Included in the 2-Piece Kit:
  • Two (2) 50cm RGBW SMD30 Strips
  • One (1) wiring harness (4-foot)
  • Two (2) quick splices
  • One (1) red LED toggle switch
  • One (1) DC-to-DT adapter
  • Four (4) zip-ties
  • One (1) 3M outdoor adhesive pad
Included in the 4-Piece Kit:
  • Four (4) 50cm RGBW SMD30 Strips
  • Eight (8) zip-ties
  • Two (2) 3M outdoor adhesive pads
  • Two (2) RGBW M8 extension wires
The 2-piece kit includes everything you need to install LED strips in the front footwell area on both the driver and passenger side of your vehicle. The 4-piece kit includes everything you need to install LED strips in the front and rear footwell areas on both the driver and passenger side of your vehicle. This kit is very universal in nature and can be tapped into any 12V power source that you would like when installing.
Any questions email us at [email protected]
PM us for the free-shipping code (U.S. forum members only)
Thanks!
Collin O.
Ok, I like this.
What about "pulse" with music? Is there an additonal controller or something to wire in?
Also can they be wired to come on as factory interior lights and then have a bypass so that I can turn on and off at will?
Thanks for your question! The strips do not pulse with the music, however that is a great idea and we may be able to develop something like that in the future.
As for your second question you can do so by using a SPDT switch instead of the SPST one that comes with the kit, you can essentially do it like this. We recommend this change only by those with electrical experience, since you will need to locate the door or map light wire and run that wire to your new switch. Please see our diagram here- the actual wiring is quite simple. If you would like a SPDT switch instead of a SPST LED switch, please just let us know after checkout. Thanks!
Text Font Line Diagram Parallel
We will be releasing a sound controller in 1-2 months, priced at $10-$15. It will be plug-and-play, so you can simply plug it into your existing single-color kit, or replace the RGB controller in your RGB kit. We're all about keeping things plug-and-play!
Thanks!
Paul
How weather/water proof are the strips.
I've considered putting something like this next to the front grill to illuminate it. I can cover and seal the wire and connectors, but the LED strip itself is a different story.
And specs on how well they hold up to heat/cold with Constant temp changes?
They seem to hold up pretty well as we have had other users do the same thing. We do, however seel weatherproof strips as well for that specific application. I would recommend using those.
here is the link RGB Multicolor Flexible 5050 SMD LED Strip (Weatherproof) - LED Strips - LED Bulbs
Let me know if you have any other questions.
- Matt
I installed my multi-color this weekend. When I get time and decent light I'll take some pics. I mounted the switch in one of the blank buttons on the assembly to the left of the steering wheel. That was not nearly as easy as I thought it would be, but it looks better there so it was worth the extra 2 hours I think I spent drilling, cutting and grinding.
Pics as promised (I know they are spectacular quality) These are the multicolor ones. You can strobe, flash, sequence, solid color (like 16 colors) and adjust speed and brightness.
Passenger Side (the strip is a little long for the mounting surface)
Driver Side - Notice the switch cluster has the LED switch in it. If anyone tries to do this, DO NOT DRILL THROUGH THE BACK!! Hyundai makes those units as a consolidated part, those button areas are not modular. I had to end up cutting out the side (after doing a careful back side pilot hole) and gutting plastic from the button face. Lots of hot knifing involved. It is just deep enough to let the blade connectors on the wires clear without pinching them in. The back of the assembly contains a PCB (printed circuit board) that Hyundai uses to attach the various button modules depending on the build of the car. So if you drill through the back, you will probably destroy the whole assembly and have to buy a new one. If you look closely you can also see the quick MOD Turbosocks had posted for the Bluetooth OBD adapter for the Torque app.
The IR receiver for the RGB module is mounted above the USB plug. I drilled top-down under the starter button to just push it through. The RGB module sits to the left of the starter button inside the console. (The pic is for the Mission Plate, but you can see the receiver.) Btw, the "V-console" is a pain to get out. Those things are really in there and the soft vinyl material of the dash and console components indents very easily from tools. Be careful when taking stuff apart on the front end. I've got a couple indents around the pry slots.
Reactions: CloDan
Nice pictures! I'm curious where Diode Dynamics installed the lights. I don't want them showing as from that picture rather hidden but there is really no where else to mount these strips unless it is shown from the previous pictures.
Discussion Starter · #14 ·
Sometimes there's a lip underneath the dash that allows the strips to stick up there. If not, use some zip ties and just tie the LED strips in place using existing wiring underneath the dash.
interested in this as well as all led interior leds. any deals?
There currently aren't any ongoing deals do to our already low prices.
-Garrick
To get at the back of the cig lighters did you have to remove the whole front panel or was their and easier access?
Ordered it yesterday. Site said it was in stock and would ship yesterday if I ordered in the morning. Last night my status changed to backordered :(
Site still says in stock.
Can't wait to get it, just bummed it is backordered when site says in stock.
Just got a text that said it has shipped. Guess the backorder thing was in error :smile:
Got mine today! Quick shipping. Will install this weekend sometime.
Land vehicle Vehicle Car Hyundai Hyundai veloster
Finished the install this morning. Beautiful!!!
1 - 20 of 228 Posts
